Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Door ajar wont turn off now everything going wrong
Reply
Thread Tools
Old 08-30-2013, 01:26 PM   #1
cherylea1
Charlton, Ma
04 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi I have a 04 Explorer
For the last 3 weeks my door ajar light wont go off, also my brake lights keep staying on (and manually have to hit brake pedal after shut off to turn off) as well as ABS light occasionally keeps appearing and disapearing.
My battery now seems to be failing bc the interior lights were always on bc it thinks door is ajar (which it's not) I changed out the door switch to the drivers door also greased the hinges and such before changing (this is the problem door) nothing changed, still same problems. So I took out interior lights so it stops draining battery and yet my battery is acting up now.
Didn't start for me yesterday morning so I jumped it, last week I charged my battery for 3 hours hooked up to battery charger while working. Battery was great for couple days and seems to keep draining for some reason.
Still have door ajar light on and cant figure out what problem is.. Please Help!! Thanks in advance -Cheryl
cherylea1 is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-30-2013, 01:32 PM   #2
cherylea1
Charlton, Ma
04 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
also forgot to mention, starting last night in my driveway letting my car run a bit to see if it would charge up, now it smells bad of rotten eggs. Is this from the battery being junk? Smells just in idle also while driving
Old 08-30-2013, 01:58 PM   #3
Jesla
Johnson City TN
05 XLT Sport Trac (4X4)
Vehicle Specs
Quoted: 0 Post(s)
Check for broken wires in the door flex joint. Drivers first then the passenger side.
Jesla is offline   Reply With Quote
Old 08-30-2013, 02:18 PM   #4
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Vehicle Specs
Quoted: 931 Post(s)
If it's the original battery you are WAY overdue for replacement. Start by having it tested and check all connections.
swshawaii is offline   Reply With Quote
Old 08-30-2013, 04:27 PM   #5
03explorereb
cuba, missouri
06 explorer xlt
Vehicle Specs
Quoted: 5 Post(s)
as far as the door ajar problem goes, i would spray the crap out of all doors at the striker with some wd40 or other suitable lubricant. i had the same problem with mine thinking it was the driver's side only to find out later that it's the passenger side causing the problem.
03explorereb is offline   Reply With Quote
Old 09-01-2013, 02:57 PM   #6
catlin
Signal Mountain TN
2002 Explorer XLT
Vehicle Specs
Quoted: 4 Post(s)
Don't assume it is the driver's door. The door ajar switch on the passenger door can cause all these problems. See my post 8/31/13 jiggle test. Catlin
catlin is offline   Reply With Quote
Reply
Tags
abs light, battery died, battery drain, brake lights, door ajar
Similar Threads
Thread Thread Starter Forum Replies Last Post
No dash lights & turn signals are bright. dastucke Stock 1995 - 2001 Explorers 1 09-27-2010 11:00 PM
Left turn signal forgot how to do it's job? U235 Stock 1995 - 2001 Explorers 4 12-15-2009 11:38 PM
95 Ranger Turn Signal problem stevejmason Ford Ranger - Mazda B-Series Forum 7 02-10-2007 12:02 PM
Don't see the movie ''Wrong Turn''...it sucked! alphabets13 Exploring every thing under the sun!! 20 06-05-2003 07:18 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
