Which transfer cases will "bolt-in" to 97 Explorer Control Trac | Ford Explorer Forums
Chucklee
Calumet, MI
1997 Ford Explorer XLT
Ok, fun stuff: my Explorer lost high range (I know it's a bad fork, but I need it fixed asap so not looking to order parts, tear apart, and rebuild), so which transfer cases will bolt in? I'm looking at local junkyards, and if I can expand the selection of transfer cases to choose from that could help greatly at finding one, especially considering the 240 inches of snow covering all the junkyards.
If I will have to manually engage 4wd, that is fine; I can work with that (Even if I have to spin the shaft with vice-grips from below). I'm looking to do minimal wiring work, as in I don't have to change any modules. So, basically, what will bolt to the driveshafts and to the rear of the tranny?
97 Explorer XLT Control Trac 4dr with 4.0L Auto.
no an answer just want to follow this thread sorry for commenting without an answer
Possibly the 13-54 manual case? I wish I knew for sure, but I am not familiar with the dimensions of the Contral Trac transfer case.
Thanks for the help! I'm going with the 1354 manual. $200 and it'll be ready for me Monday from the local salvage yard. Feels good!
So, for anyone interested, as far as I can tell, I need a 1354 (w/ lever and boots) and a driveshaft from a 95-96 Explorer. I need to make the vss work, so I'm not sure yet if they are interchangeable, but I will find out when I dig in. I plan on doing a simple how-to with pictures, even though I have read repeatedly that this has been done countless times (amazingly, a search doesn't produce one).
