- February 18, 2009
- Winnipeg, Manitoba
- 04 Mustang GT
Ok boys, who remembers their math?
I've been trying to sort out my analog equation for my AEM digital boost gauge.
What I have been looking at is this:
http://www.svtperformance.com/forum...ital-Boost-Gauge-to-datalog-with-SCT-livelink
The gauge swings from -30 to +35 and is a 0 to +5v analog output. That's a swing of 65 points over 5 volts
This is the formula: (v*13)-32.0 Problem is, its wrong.
It works at 21 lbs vacuum just fine (-21)
At 10 lbs boost, the equation gives a result of -1.4 obviously, I should get +10
Now, how do I figure this out using the above info, rather than trying to use a voltmeter and creating boost/checking each voltage?
Im just not that good at this anymore. I know it should be reasonably straight forward, but its not coming to me.
so, this 'might' be close: (v*20.7)-39
I didn't take the scientific approach, but the voltage output does not appear to be completely linear.
Unless someone had a better idea, I'll do some logging with this and let you know if it works.
