Caejxr
- September 21, 2009
- My explorer eats money
- '97 Turbo 4.0 OHV
Well I got tired of the 4.0 ohv not having any power on the highway climbing the hills on the 62 and having no low end in 4x4 high offroad, especially now that I have a pickup with a 5.7 v8 in it..
I've been lurking for some time since I've been kinda busy with work but, I got my hands on a Turbonetics T3 T4 hybrid so it's project time. It has the .48ar T3 turbine and a f1-57 trim T4 compressor. I expect this thing will spool FAST but I am not making any claims to being too familiar with forced induction..worst case scenario is there's a problem I can get a higher trim turbine.
I plan on having it live just behind and to the right of the alternator after doing test fitting. Its snug but should work nice to draw through my snorkel set up and for routing the exhaust.
Now, I have a concern about drawing through the stock airbox with a K&N drop in.. will this be too much suction and cause oil to get past the center housing seals?
If I hit full boost before highway cruising speed will that boost still be effective once in the higher RPM's? ie: is 7lb boost (where I plan to limit it at) at say, 1500 rpm still 7lb boost at 3k rpm?
Anyway, thanks in advance for the guru advice and input. I'll try to post through the project and get some pics up since everyone likes pics.
'merica
