JakePSD
- March 25, 2010
- Ohio
- 2003 Mercury Mountaineer
I have an 03 mountaineer with a blown motor at 287,x.. miles. Timing chain failed somehow it seems. Chains and sprockets were intact, however the right side guides were all chewed up and broken, and all 4 right side intake valves smacked the pistons and broke all 4 of them off in the cylinder.
I bought an 02 for parts with a good running engine. It has 176,x.. miles on it. Before I put the motor in the 03 I want to do some preventative measures so I can have years of trouble free service. One of those things is preventing the failure that has now given me a couple hundred pounds of scrap cast aluminum.
My main question is, is there any problem with just changing the guides and tensioners and not replacing the chains and sprockets? I wanna save money where I can but don't wanna cheap out and have issues down the road. My logic says its ok, reason being that if the chains and sprockets held up to the abuse of valve/piston contact, enough to break the valves off, then they are well built enough to not warrant replacement on a perfectly good running engine.
A couple side questions, I noticed that early 02's had cast iron tensioners and metal backed guides, whereas late 02+ have all plastic construction. I'd have to assume the metal would be stronger and last considerably longer than plastic. Are they interchangeable? Can one put the early 02 (metal) parts in a late 02+ engine without problems? Would that be a good idea for longevity? What reason WOULDN'T I do that? Also, if anyone wants parts for a good price, obviously I have a parts truck.
