tcbarney
- December 20, 2001
- Canton, GA
- '96 XLT 4x2
I had posted the following to an old thread, but it resides in Under The Hood, which is not really where this subject belongs these days, so I post here to get a little more visibility:
(the original thread is Dead Link Removed )
Doing a lot of searches to see if there is a definitive answer to this issue. From this and other threads, seems like it could be any of several things:
1. Bad thermostat
2. Air bubble
3. Bad radiator cap
4. Clogged radiator
5. Bad water pump
6. Bad fan clutch
7. Loose wires
8. Head gasket leak
9. ....what else...?
I just noticed mine doing this flucuation recently. Did a 60k service just a couple months ago, where I flushed coolant and changed t-stat and rad cap.
Then, on Thanksgiving, got a chirp when I started the car that my brother said sounded a lot like when his water pump in his SHO started to go bad. And I think I caught a whiff of coolant after I parked the X. Haven't crawled under yet to see if the weep hole is weeping.
So my problem may be a water pump starting to go. I will post after I replace it and let this thread know if it helped the gauge problem. I'll not do the tstat and rad cap again right at first, so I can tell for sure if the H2O pump did the trick.
1. Bad thermostat
2. Air bubble
3. Bad radiator cap
4. Clogged radiator
5. Bad water pump
6. Bad fan clutch
7. Loose wires
8. Head gasket leak
