- July 5, 2003
- Brockton, MA
- '93 XLT 4x4
Don't Despair I have been down the same road as you..
When you say the "motor" works when engaged manually I am assuming you mean you removed the electronic shift motor and turned the Transfer case selector from 2H to 4H and it worked (Am I correct)? In my experience 99% of the time it is the electronic shift motor and it's geared selector which are the problem. Did you verify the shift motor worked? If not I would:
1) remove the shift motor
2) mark the position of the geared selector cover.
3) remove the shift motor's geared selector cover (held in by security screws)
4) remove the geared selector. (verify the stop hasn't fallen apart) if so remove the broken pieces and replace with a small piece of 5/16" hose over the stop bolt.
5) apply voltage to the shift motor to verify the worm gear moves. There are 2 wires coming from the motor, apply + to one and - to the other (doesn't matter which way). Do this for 30 secs and stop, wait a minute and then repeat... This will help unstick a shift motor that is binding from lack of use. Reverse the +/- on the motor (it will now run in reverse) and run repeat the above.
6) Verify the T-Case selector is in 2H and re-install the shift motor (without geared selector in place).
7) Install the geared selector and clean the electrical contact area with some rubbing alcohol to remove any oxidation that has formed.
8) Install the geared selector cover (clean its contacts). This step is where the motor will fail to work if not installed 100% correctly. The cover contains electrical fingers which need to line up with the contacts on the geared selector. If they don't the 4x4 module in the trunk will have no idea what position the T-case is in and will nothing (as a safety precaution). This is the problem I originally encountered. I basically installed the cover to the position I had marked when it was removed. I then used a meter to verify the continuity of the wiring harness. Some wires didn't have continuity and I had to rotate the cover 1/8" to achieve it. If you don't have a meter you can install the cover to the position you marked and try pressing the 4x4 button. If nothing happens, loosen the cover and slightly rotate it 1/8" in one direction and retest. If still nothing then after 1/2" of rotation then return the cover to the position and repeat the above but rotate the other direction.
I will dig up the wiring pins tonight when I get home.
