Replacement of cooling fan??? | Ford Explorer Forums
  • Thread starter Thread starter Chumley
  • Start date Start date
C
Chumley
Any recomendations on new cooling fan, my 92 explorer 4.0 fan has numerous cracks in it??
Thanks
My 90 4.0 Ranger 4x4, 91 5.0 Mustang and 92 4.0 Explorer 4x4 also developed those cracks. I replaced each as needed with parts from Ford.
So far the cracks have not reappeared. Aftermarket wise, there's a kit to replace the fan on the Mustang with an electric kit, but I haven't seen one forthe Explorer/Ranger users. The fan from Ford was $48.00 ea.
Krokus
Cracks in Explorer fans is a very common
problem, so common that my local dealer stocks them like they stock other commonly replaced parts. You do need to replace it though because if it shatters I can guarantee
that you will be sorry.
Barry
91 Explorer Sport on its 3rd cooling fan after 155,000 miles.
My cooling fan has cracks in it to. I thought i remembered seeing aftermarket fans in Summit Racing. Can anyone back up my memory.
Thanks fellas
Do you mean the electric fans or replacement ones? I've been looking for an electric fan that would fit, anybody know where to find one?
I know flex-a-lite makes an electric fan for the explorer. it is the same basic model as used for the mustang, just a little different mounting procedure. i believe it is like $189 dollars from JEGS, but not 100% sure. Flex-a-lite's part number is 175, for the kit. Hope this helps.
Terry L. Knotts
[This message has been edited by Scrambler (edited 06-29-1999).]
I am talking about just replacement fans. How much hp could you gain by going to electric??
I just ordered the Flex-a-lite electric fan from Jegs. I'm hoping to free up a few horse power, but most importantly I'm hoping to increase the airflow through the radiator and A/C condenser at low, rock crawling speeds.
Since this fan is designed to handle the output of a V-8 Mustang I think it will do a great job with the V-6 Explorer.
Rick Horwitz
explorer@4x4central.com
Editor
www.4x4central.com
I'm interested in ordering a fan...what is JEGS?? I have a 91 EB will mine take the same as yours Rick??
I'm also very interested in this fan, could you tell me how it works out? I assume it's temperature opperated, was it hard to pu the fan switch in, or could you hook it up to an existing sensor? And is it set to were it's always on if your A/C is on? Thanks!
Jeg's can be found at http://www.jegs.com
I'll let you know how the install goes next week after I get a hold of the fan. I can tell you that the kit comes with a thermostatically controlled switch and an A/C relay. How it all works together is yet to be seen.
Rick Horwitz
Editor
www.4x4central.com
I had a replacement electric fan on my Explorer. I can't believe how quiet the engine was (No more roaring sound) and the extra giddy up go (excuse me, it's late).
Then...I was 4wheelin when my buddy in his full size Bronco kept getting stuck in the deep snow. The poor little (16 inch) fan could not keep up with my persistance in pulling out the full size. I ended up running the heater full boar with the windows down and about 35F temperature.
The Explorer never gets hot 4wheelin. But in the extreme case I did not want to deal with an overheated motor.
So for now I have the clutch fan put back in and the electric fan mounted on the front of the radiator support for additional cooling. The adjustable thermostat is set higher so the fan doesnt kick in as much.
My Explorer has a single core radiator. I figure when I upgrade the radiator I will get another electric fan to replace the clutch fan.
Rick-Be sure and let us know how the electric fan works in the +100F days, with the AC on, in stop and go traffic...that is my goal...
David Meisner
Ray, who's fan did you go with? Was it a Flex-a-lite 175 series? I sure hope not. I talked to those guys and told them what my situation is, 100+ days in Phoenix, slow speed rock crawling with A/C on etc. They said it would work great, but then again they're trying to sell their products.
I will definately review the product and let everyone know how it works out.
Rick Horwitz
Editor
www.4x4central.com
The fan that I bought was an el cheapo ($75) from Autozone. That was half of my problem and why I am going to leave it as a secondary behind the grill. Besides, it looks pretty trick that way.
I think it was a Crown? The motor hub got really hot so I kept the box to return if it didn't work out and eventually I just swallowed it. Dead Link Removed
I would try to get a fan that was about 18 inches so it covers most of the radiator. You may also experiment with leaving the fan shroud on to help suck the air through the radiator.
I did however like the room without the fan and shroud. It looked cool with the serpentine belt just spinning.
David Meisner
PS-Once you go with the electric, you will hear sounds you never heard before from the engine/acc's.
Rick, what was the part number on the fan you bought? Was it the 400-M40? Just trying to figure out which one you got, because i'm very intersted in one. What did you pay for it?
400-M175, $193.99
15" diameter blade.
Measures 18"x16"x4-1/4" deep.
Pulls 2800 cfm of air.
Draws 13.9 amps @ 2200 rpm fan speed.
Lightweight one-piece plastic shroud mounts as a "puller" behind the radiator
with a full contact rubber seal. This rigid bracket mounting system means no
through-core mounting required.
Great cooling for 4 x 4's and higher HP applications.
Restores horsepower by replacing stock fan, extends water pump life &
increases gas mileage.
Rick Horwitz
Editor
www.4x4central.com
I just installed my Flex-a-lite 175 electric fan kit.
It fits perfect. Even though the box says 5.0L Mustang it fits the 4.0L Explorer radiator perfectly.
The hardest part is removing the fan and clutch. I opted to have a garage which is only a block away remove the clutch for me. I drove it home with no fan at all. No problem with the heat in that short of a distance.
Once I got it home I removed the stock fan shroud. Then I installed the electric fan using their instructions. They were very clear and easy to follow. First attach a couple clips to the top of the new fan assembly, hook it to the top of the radiator, (it helps to have someone hold it in place). Next attach the clips to the bottom of the assembly using the spacers which are included. Tighten the bottom clips, then come back to the top and tighten those clips. The top clips will bend slightly to form a tight fit.
Next is the wiring. I wired mine so it will come on even with the engine off. This helps dissipate engine heat after the engine is turned off. I also used the built in A/C relay which causes the fan to run whenever the A/C clutch is engaged. This ensures good airflow across the condensor. You need to splice into the positive side of the A/C clutch connector. On my '93 it was the top wire of the pair.
I have yet to test it during the day. I ran it at night with the outdoor temp still above 95 degrees and I kept the A/C on max. I drove it through traffic, let it idle for a long time and so far so good.
Tomorrow will be the big test. Close to 110 in Phoenix and I plan on trying it offroad to see how it does with the A/C on and crawling slow on the trail.
Stay tuned...tomorrow night I'll let you know how it did.
Have a great 4th of July weekend!
Rick Horwitz
Editor
www.4x4central.com
Well, it was 105+ today and I have to be honest the fan sucks. And I don't mean air either.
I will contact Flex-a-lite on Tuesday to see if they can offer any suggestions besides returning it.
Problems:
1. While traveling at freeway speeds with the A/C on the electric fan is constantly working and it actually restricts airflow. Engine temperatures were soaring on the freeway, the faster I drove (up to 75) the worse it got.
2. Stop and go temps were jsut slightly higher than with the stock fan.
3. I tried it offroad for a while. I climbed a hill in low range with the A/C on and by the time I got to the top it was close to over heating.
In my opinion this fan is worse in all conditions than the stock fan at least when it's 105+ in Phoenix.
What really bothers me is that I told these guys the EXACT conditions I would be using the fan under.
I can't believe the fan would work any better in a 5.0 Mustang which makes way more HP than our Explorers.
Rick Horwitz
Editor
www.4x4central.com
Rick,
I think the way to go with electric fans is to use one from a car that came from the factory with one. I have never seen an aftermarket electric that could keep up with an OEM fan. You might want to go digging through the junk yard with your tape measure and find one that will fit.
I used to have a '76 Saab 99 2.0L, the electric fan that came on this car pulled an unbelievable amount of air. One day I will track down one of these fans and install it.
Paul Gagnon
"No Brain, No Pain"
Dead Link Removed
