mattadams
Moderator Emeritus
- September 17, 1999
- Longmont, CO
- 2017 Explorer Sport
Well as I told most of the guys in Moab, my rear locker was broken in Moab, not sure why but its possible it broke doing Double Whammy... who knows... regardless, it wouldn't disengage and was making awful noises... anyways, took it in today and heres the list of everything that was destroyed...
Both spider gears (one was missing two teeth, the other was missing three teeth... not sure how that happened)
Clutch Gear
Differential Case
Cross shaft
Piston
All bearings within the ARB
Cylinder Cap
Splined Side Gear
A few other little miscellaneous parts - now that was teh ARB...
it seemes that when the ARB blew it also took out three teeth from the main ring of the 4.56 ring and pinion, so thats basically bad...
all pinion bearings
pinion seal
rear wheel seal
housing gasket
new differential cover (this wasn't bad but I figured better replace it anyway)
So in conclusion, I'll be replacing the entire ARB locker unit (hopefully under warranty) as well as the entire rear ring and pinion (unfortanetly this won't be under warranty since the blown out ARB caused the chips)... I took some pictures of the gears, etc. so hopefully i'll have them in a few days.
Lucky me!
Matt Adams
94 Explorer 4-door nick-named "Tippy"
http://bart.is-s.com/~explorers/explorer/explorer.html
Clutch Gear
Differential Case
Cross shaft
Piston
Cylinder Cap
Splined Side Gear
all pinion bearings
pinion seal
rear wheel seal
housing gasket
Lucky me!
Matt Adams
