Diff Whack Daddy
And the Roll Over Posse! Under the Hood Moderator
Moderator Emeritus
- February 19, 1999
- Mount Vernon, WA
- 1st Gen XLT 4dr
- Callsign
- KG7VTT
Okay here is the problem or advantage, you tell me. I call it both, because if you never lift both tires off the ground, It's not a problem. But with both tires off the ground, suspension at full droop on bith sides, The passenger side axle does not compress enough. I figured this out when the mechanic at 4 wheel parts couldn't get the passenger side axle shaft back in far enough to replace the spindle.
Now if your thinking its the locker, its not. When I pulled it apart to replace the diff case, the c-clipped axle was right up against the center pin of the carier. After the locker install, It was in the same place and you could also clearly see the axle seal was hitting the axle in the same place. By using a comalong, we compressed the dricerside suspension and the passenger side spindle went right on.
However, this does not cure the problem. The stress is still going to be there on the spindle or the axle shaft itself and u-joints. Since I never plan to have both sides in the air at the same time, I don't see it as a big problem, but it does put unneccecary stress on the components.
We have decided to cut the c-clip flange off the axle and see where that puts it. By putting a spring in the flex joint, it will keep both sides of the axle pushed out enough to keep it from sliding out of the diff. This will give me about a 1/4 inch at the axle housing and about 1/2 an inch at the spindle which is just about what I need.
If you have longer than stock springs, you might want to check and make sure this isn't happening to you. Could be another Superlift 5.5" lift flaw too.
