Before & After '98 Sport with NEW Trailmaster Lift | Ford Explorer Forums
Djohnson
Elite Explorer<br><img src="/forums/images/djohnso
ILLINOIS
'98 SPORT
Here is My Sport this Fall without the lift.
View
Here is My Sport this Winter With the lift.
View
[Edited by Djohnson on 01-03-2001 at 09:13 PM]
Looks Good!!!! Seems like you have larger tires in the back since the front is sagging :)
Nice looking truck, do you think a torsion twist good fix the front??
Thanks for the Complements!
Visit my thread in the Shocks, Suspensions, and lift Kits. I explained some of the problems that I had with the lift.
Right now the torsion bars are backed all the way down. As soon as I get it fixed I will get at least another inch in the front.
That looks so cool! How is it living with the lift, like, the everyday driveability in traffic, around turns, parking, visibility...
Thanks..
Looks great! The lift gives is a pretty aggressive look
Dude you stole my truck!
Dead Link Removed
Here is my 97 Sport before the Warrior Shackles.
Djohnson,
that is one fabulous looking truck. the tires look awesome. did u have to do alot of trimming to fit them in the wheelwells?
Rick
No, not much trimming. I spent about 10 minutes with a Dremel tool to cut off that little plastic leg on the back of the front finder wells. I also moved my front bumper out 5/8".
Nice truck! I think the Sports look awesome with a few inches of lift. Nice job!
Hey Nice truck! I've got one but its red and 2wd. About what size are your tires? I'm thinking of 33's and 7.5 in the front and 8 in the back. Are you going to do a body lift as well? If you do decide to do it, i would love to hear about it. Thanks
TURDS
Thanks,
My tires are 285 75 R16, that is equal to 32.8" in diameter. I don't plan on doing a body lift.
**** "How is it living with the lift, like, the everyday driveability in traffic, around turns, parking, visibility..." ****
For the most part the truck seems the same only much cooler! This lift encorporates double rack steering. The fit of the brackets was just a little off so when driving on the interstate I have to keep steering. It might have something to do with my caster.
Cornering is OK, I just take it a little slower now. The steering wheel will return to center after turing a corner.
Parking is still no problem. No rubbing when at full turn.
I love the visibility that I have. I can now see down into explorers and other trucks!
Hope this helps.
DJ
[Edited by Djohnson on 01-19-2001 at 09:27 PM]
How do rate the trailmaster SSV shocks compared to stock ones? Do you rock from side to side entering drive ways or speed bumps? Stock bounces all over!!!
I'M NO EXPERT ON SHOCKS, BUT I CAN TELL A VERY BIG DIFFERENCE BETWEEN THE SSV'S AND THE OE SHOCKS.
THE RIDE IS MUCH BETTER IN MY MIND NOW THAT I HAVE THE LIFT ON. IT RIDES A LITTLE MORE LIKE A TRUCK SHOULD.
Originally posted by Djohnson
The fit of the brackets was just a little off so when driving on the interstate I have to keep steering. It might have something to do with my camber.....
DJ
Check your caster first, not your camber.
PS/ Awesome work. The lift should really help you. Congrats!
OOPS, I meant caster. Thanks GJarrett.
Your truck was my inspiriation if you could not tell.
Thanks,
DJ
DJ- Where is Gilson located? There are quite a few Illinois guys meeting in February....Just makin the offer open to ya. Check the threads "Trails in Illinois" and "Who Lives In Illinois"
Pete
