BIG COUNTRY
- April 11, 2003
- EIELSON AFB, ALASKA
- 1998 XLS 4x4
i will advise everyone to get a service manual cd rom from ebay for only $4....it shows every thing...all the wires and locations
things to have:
message center, lamp warning module, and low washer fluid sensor...lots of wire and connectors!!! and most of all....patience!!!
message center harness: the bigger harness connector
pin/wire color function/ and location
1 L. Green goes to the M/C...already done
2 Blue/Red illumination: dimmer module
3 Yellow/ White fuel level input: at the cluster
4 not used
5 Blue/ Pink fuel flow input: at the PCM
6 Yellow/ Red lamp out warn. module by the M/C
7 Green/ L. Green goes to the M/C...already done
8 Red/ White engine temp sense: at the cluster
9 Green/ White oil temp input: middle harness under the fuse box in engin compartment
10 Grey/ Yellow hot at ignition: i wired it to stereo
11 Grey/ Black speed sensor:4wabs mod. by battery
12 Pink/ White air ride control. dont have it, forget it
message center harness: the smaller harness connector
pin/ wire color function/ and location
22 Green/ L. Green air rid control: dont have it, forget it
23 White/ Pink low oil level input: botton of oil pan
24 Red english/ metric output: EATC
25 Tan/ Yellow chime output: GEM pin 20
26 not used
27 L. Green/ Yellow hot at all times: i wired to stereo
28 Black/ White power ground to Data Link Conn.
29 Orange/ Black lamp out warn. module: by the M/C
30 Red/ Green lamp out warn. module: by the M/C
31 Pink/ Yellow low washer fluid sensor: fluid bottle
32 Black/ White chasis grd. not w/ other Blk/Wh wire
33 not used
34 Tan/ Yellow tach input: at the cluster
35 not used
36 Black ground....chasis
Message center harness: the harness to the buttons
1 Green/ L. Green to the M/C....already done
2 not used
3 Black/ White power ground...to Data Link Conn.
4 L. Green to the M/C....already done
5 Black ground...chasis
6 Red/ Black illumination: ash tray or stereo
Lamp out warning module harness:
1 White/ Green left headlight: fuse panel pin 4
2 Red/ Green headlight out warning: to the M/C
3 Orange/ Black rear park lamp out warning: to M/C
4 Yellow/ Red brake lamp out warning: to the M/C
5 Dark Brown rear park lamp input
ark lamp relay
6 White/ Green park lamp output: left/and right rear light
7 Grey/ Yellow hot at ignition: i wired to the stereo
8 not used
9 Black ground...chassis
10 not used
11 L. Blue/ White left headlight output: left headlight
12 L. Blue/ Green right headlight input:fuse panel pin 8
13 Green/ Orange right headlight: fog lamp relay
14 L. Green stop lamp input: brake pedal switch
15 Red/ White stop lamp output: left/ and right rear stop light
16 not used
be very advised that there are same color wires...so look what pin they are coming out of...
for the Blue/ Pink wire off of the bigger harness connector for the M/C (Message Center) goes to the PCM located in the engine compartment above the heater hoses in the middle....PIN 43...if you dont have this which most of you will not...dont worry, i didnt either...alls you have to do is get another pin from the junkyard and take your red clip off of your harness...and drill a little hole...the size of the pin and once that is done...poke the wire thru until it clicks...and there you have it...now you know how many gallons you have used and how many miles you have left in your tank...
SOHC engines will most likely to have this wire already.
for the Pink/Yellow wire off the smaller harness connector for the M/C that goes to the washer fluid sensor...you wont have that so you would need one from a junkyard or buy one...but you must get a harness for it from the junkyard...once you get that...take your bottle out and drill a hole til where it will fit...then plug it up with some silicon and set dry...
for the White/ Pink wire out of the smaller harness connector that goes to the low oil level sensor....you will need to buy one at the junkyard for $10 or get one from ford for $40....but again, you will need a harness...i didnt hook this one up yet cuz i havent gotten a sensor yet...alot of you will not have this cuz you dont have a message center in the first place
the cd rom says that the lamp out warning module has been deleted for the late production explorers and for early 98 explorers will just act as a jumper...so i guess it wont read if you have an out...mine always say check my lights...im guessing it is because the ford dealer said that there is a message center for each year...my 95 Message Center wont work properly on my 98 explorer...so i guess i have got to get a 98 Message Center for it to work properly...however it does read how many miles i got left, how many gallons i got and used, reset my oil...english to metric, and system check all work properly...so if you are gonna get a Message Center put in...get one that goes to your year of explorer...
if there is anyone out there that can put this thread in the list of useful threads or tech tips...please do so, alot of explorer owners would like this mod!!!
good luck to everyone....
things to have:
4 not used
26 not used
33 not used
35 not used
2 not used
8 not used
10 not used
16 not used
