Eli 91 XLT
- July 31, 2003
- Central Valley, Cali
- '91 XLT
Hi guys & gals. I've had this problem for about 3 months now..
http://www.explorerforum.com/forums/showthread.php?s=&threadid=84534
and starting to feel the pressure of getting this fixed once and for all. If you read through the thread, you'll see that my tranny had gone out and once I changed the fluid/filter I got my tranny back EXCEPT for overdrive. Since we've only been driving it in town, no OD has not been a problem till now. My commuter truck is having small problems and might have to use the XLT as a commuter starting next week, so I need OD. Please help, by pointing me in the right directions. After doing a search, I've come across of things to check/replace (money depending of course). Please add/subtract to list to help me get this figured out. What should be checked first, etc..
1. TC lockup selenoid
2. Mass airflow sensor
3. Speed sensor
4. ????
BTW, all other gears work fine. Here are the gears I feel it go through 1-2 (shifts around 20 mph) 2-3 (shifts around 30 mph) 3-4 (shift around 45 mph) then that's it. It does about 2500 rpms at 65 mph. Also it will hunt for gears when moderate pressure is put on the gas at this speed. Thanks guys/gals.
3. Speed sensor
4. ????
