02 explorer 4.0 4x4 od off light blinking only | Ford Explorer Forums - Serious Explorations
gt5228
02 explorer
So i did have my od light blinking and abs light on so i replaced the vss and the abs hasnt turned on since, only problem is that the od off light blinks continously once the truck warms up. it has no shifting problems what so ever, actually it shifts like a dream! any advice? i just bought it so im not sure what was done on it before...
Have your local auto parts store scan the computer for a code. Problem could possibly be in the transmission and it could cause more problems if not looked at. Check the fuses first, and then see if there are any codes stored. I had the same issues 3 years ago and I bought that aftermarket servo kit. Some say it is a band aid fix, but it worked perfectly for me. I spent 100.00 compared to spending 3500 for a a complete rebuild and no problems after putting on 30000 since the repair.
good luck
bizzs
