Smear
- December 18, 2017
- SoCal
- 03 Expl 4.6L XLT 3.73LS
Hi all! I am a new member, so forgive me if I mess up on making this thread. I have had this problem with my 03 Explorer (150k) for a good 5 months now (since I got it). It is a RWD and has a 4.6 and the 3.73 LS axle. I've been getting pretty bad gas mileage, about 9-12 mpg. No CEL and no fluids on the ground after I park it. It does not idle roughly. The plugs were changed 2-3 years ago. Replaced thermostat and performed coolant flush (heat was not working well, warmed up very slow and heard a bad thermostat reduces gas mileage) and cleaned my air filter. Also performed an oil change and put a new serpentine belt in (old one worn). Warms up quickly and heat works now, but gas mileage still bad. I use my Ex as a commuter in my town, but my commute is mostly highway at 55 mph. I am getting around 220 miles to my 22.5 gal tank. Previous owner (and relative) said he used to get a good 300 out of the tank. I do not tow or carry anything and I don't floor it often. There's an occasional loud 2 second rattle on cold start which has already been diagnosed as a cat shield. There's also a burning smell (especially after I've run it hard), but I think that's just oil burning somewhere on the manifold. My first oil change I did on it, it was missing a tiny amount of oil so no surprise. I've also noticed my muffler has a few small cracks in it, maybe something to do with back pressure? Maybe this kind of mpg is normal with the V8? Are you guys having this kind of mpg as well? Our '13 F150 with a 5.0 gets about 16 mpg, so this kind of mileage is a bit unusual to me even for a V8. I do have a slight vibration at idle when the the truck is in drive, and I do have the notorious lunging transmission. Lunging only occurs when I'm shifting into Drive or Reverse and when i let off the gas after getting on it, maybe torque converter lockup issue? Looking forward to your responses!
