Guedes1997
- February 3, 2017
- NJ
- 2003 X XLS 4.0 Flex 4wd
Hi I am a new member and I just bought an Explorer about 2 weeks ago.
I got it, it wasn't quite running well, I pulled the codes up and it was throwing a code for the camshaft position sensor. I did a tune up (spark plugs, wires, oil, all filters), changed camshaft position sensor and the car still took a lot to get to start. And kept running rough like it did plus I got it out of the parking space where it was then I went to clean up for 5 minutes, the car had no power whatsoever, I pushed the gas and nothing (in neutral or park, it would Rev up). I haven't cleared the code, does that matter? Also, tomorrow I will be changing the crankshaft position sensor and clearing the codes to see if it helps. Anything else I should check?
I appreciate any help, thank you!
Model details: 03 Explorer XLS 4.0 SOHC FlexFuel
