Funkydm
- April 20, 2013
- Deer Park, NY
- 2006 Ford Explorer
Here is what I got:
2006 Eddie Bauer 4x4 4.0 Sohc v6 121,000 Miles
Here is what happened:
Vehicle overheated due to thermostat housing melted and seam separated.
Here is what I've done:
Replaced Thermostat housing
Radiator Flush and fluid replace
Oil Flush and fluid replace
Changed PCM,spark plugs and wires
Replaced throttle body
Replaced Fuel injectors
PCV replaced
New Air Filter ( not that would do anything)
Ongoing problems:
Antifreeze is needing to be replaced everyday(no puddles or leaks found)
Rough idle when in park or at a stop sign whether in drive ,neutral or park
Heater is not working ( no puddles in passenger floorboard)
Heater will sometimes work if I drive or accelerate
Misfire on Cylinder 5 from time to time
I don't know what else to do. I have had friends run computer at shop but no problems found. Please help ideas. I only posted because all the other threads are so old.
PCV replaced
Ongoing problems:
