AnthonyMalachi
- July 14, 2018
- Georgia
- 2006 Ford Explorer XLT
Hi, I've just spent 30 minutes looking through the threads and didn't find anything on this specific problem. If there is one that I've overlooked, I apologize.
My wife's Explorer doesn't shift from park to drive or reverse unless you go past the desired position with the lever, then slowly back into drive or reverse. Then, if you shift into park, it doesn't actually engage until the car rolls a little or you rock it as you're getting out. (You can hear it click into park.) It upshifts and downshifts perfectly while driving, it's just when you are going from park to drive or reverse. Once the car is warmed up, this problem goes away. Well... the issue with going into park never goes away. Any advice or information on what may be the cause of these problems would be very much appreciated. This is her daily driver, so I can't be tearing it apart on an exploratory adventure, I need to down it for as little time as possible. I am a heavy equipment/truck mechanic, so I've got the facilities, tools, and aptitude to handle most jobs myself, but need advice from the experts on Explorers specifically. (You fine folks.) Thanks again for any help.
