chris9999
- February 3, 2024
- Columbus, MS
- 1995 XLT Sport (?)
Hi, I purchased this vehicle from the motor pool of a local government body.
The vehicle was very inexpensive, so I don't mind spending a little bit. But I also don't want to be pumping
money into a hole.
The inside is a mess but usable. The underbody is beautiful. The exterior is a bit rough but not too bad.
I has 150k miles on it.
The first thing to note is that the cat converter has been hacked out with a sawzall,
so it is loud.
Starting: I hear the fuel pump run for just a brief period. I get a pop-off after a few revs.
I stop cranking. I crank again and it pops off a bit more.
I keep doing that, probably a dozen or more times and eventually it will fire and run smoothly then die.
And if I keep at it I can get it to run, particularly if I flutter the throttle a bit and keep it off of minimum idle.
When it isn't smooth it sounds like a drag racer engine, not in loudness but in hit/miss nature.
When it is smooth it actually sounds pretty good.
The intake: The molded intake hose has holes in it. I tried looking something up at the local auto parts stores and
nothing comes up except generic hoses. What do you all do?
I wanted to get as far as I could to see if it is worth doing the cat replacement or whatever. And when the
engine is running smooth it actually sounds good and it revs good. I'm interested in your thoughts.
money into a hole.
so it is loud.
