c7j6y1
- March 1, 2010
- DFW, TX
- 93 Sport
Well so my 500 Ex may have been a too good to be true deal
So last night i was accelerating onto the highway, was in 3rd, and in the process of shifting into 4th, when the trans jumped, the tires screeched and there was a Thump!
I quickly pushed the clutch in and killed the engine, and rolled to a stop.
Well after some quick looking around, I saw no fluid under the truck, so anything appearing out of the ordinary. I got back into the truck, started it and tried to shift into 1st, well when it was no go. So i put it into neutral (or what i thought was neutral and slowly letup on the clutch.
Well turns out it was in gear!
after some more roadside diogonistics, I decided it was in 3rd and i would try to limp it home.
well It was in 3rd. I made it home with out incident, other than cursing at the red lights i came up to and felt like i was burning thru 1000 miles of clutch to get it home.
So long story short...
Shifter says its in Neutral, Trans says its in 3rd.
I talked to a trans shop this morning and nobody is saying that the trans is likely screwed, best case is that the Linkage is the problem,
worst case is that i need a rebuild... but im not spending 2K to pay somebody to rebuild...
anybody have similar problems? if so whats ur solutions?
