griffigr
- April 14, 2008
- Grand Haven, MI
- 1994 Explorer Sport
I've got a mind boggling issue. About 6 weeks ago, I parked my Explorer to fix the lower intake gasket and to replace the alternator. Today, after getting everything put back together, I start the truck to take it for a test drive, and I find it won't shift into any gear (the vehicle is equipped with a 5 speed manual transmission). With the motor turned off, the transmission shifts fine. It shifted fine when I parked it 6 weeks ago. The clutch master cylinder fluid level is fine. To get the truck into gear, I have to literally grind the gears to get anything to engage. I don't think it's the slave cylinder, because I've got plenty of clutch pressure and I'm not leaking any hydraulic fluid. Yet, I think one of the front calipers has seized to the rotor and will not disengage. Don't the brakes and clutch share the same fluid? If the caliper is seized, will it effect the shifting? Has anyone else experienced a similar problem? *note: I know it seems ridiculous to think brakes would effect shifting, but I'm out of ideas.
