1st 75th Ranger
- August 29, 2007
- 1994 Ranger
1994 V6, 4.0. Always starts when cold (say over two hours since last run). Always runs well after starting (never cuts off). However, randomly, after starting, running, shutting off and sitting for a short time, the engine will turn over but won't actually start. No sputtering, no almost start...nothing (as if no fire). Wait a little while, try again and it may or may not start. Already replaced fuel pump, filter, fuel pump relay and ignition module. Had it to the shop, but the mechanic could not recreate the problem, engine started right up for him every time (just my luck). Any thoughts? Ignition coil maybe?
