Runs in rich mode. Scan tool will not read codes. Check engine light on. Anybody have any ideas? Please? Thanx
What sort of scan tool are you using? 1995 model is EEC-IV and can't be accessed with the newer OBDII scanners. Actually, you don't even need any scanner at all to pull codes. Just ground the pin on the 'test' connector and count the flashes on the CEL. Searching for something like 'EEC-IV' trouble code reading' will provide the details. Here is a link to a youtube video that shows how to do that: https://www.youtube.com/watch?v=xdCUHULa4HM
My connector is under the dash. Is that still EEC-IV? It doesn't look like the video you had.
95 was a transition year. Some late '95 vehicles may be OBDII, but seems that yours isn't, or the OBDII scanner would work. The fact that you have the OBDII-style connector does not mean it's actually OBDII. Take a good look under the hood for the EEC-IV test connectors. If they aren't there, I heard of something called OBD 1.5, but no clue if that's even real, and if it is, how to deal with it. Perhaps someone more familiar with that year will chime in....
