allmyEXes
- February 6, 2016
- No. Alabama USA
- 1997 Blue Ex 4.0 SOHC
- Callsign
- KAGG 3611 (CB)
I have a small utility trailer that has been in the family for ~50 to 55 years and it has a "flat" 4 pin connector on it. I have used it on various vehicles that the turn signals and brake lights are the same filament in the 1157 bulb. On my old Mountaineer it had an aftermarket "tap in" harness for trailer lights and it worked well with any trailers that have been hooked to it.
Recently I hooked up the trailer to the white '97 Explorer. Well the trailer lights don't match what is going on with the truck. I took out the rear taillamp assy and someone has been working on the wiring in there. A flat four has been "tapped" into and there is some blue tap in connectors and black tape too. I assume that the PO's trailer has "custom" wiring too. I haven't checked to see if the Y/G/B and white ground are where they should be but even if I where to wire it that way I think that I wouldn't have brake light because the directional signals are yellow and the brake lights are separate red lights.
Is there a factory built in 4 to 6 (maybe 4 to 5?) wire converter box built in the left rear quarter panel? or am I going to need a small converter box to go from 4 to 6 wire? I don't have a harness to tap in to the factory harness across the back to tap in to behind the bumper.
Thanks in advance for any advice.
ADDED: I believe I found the answer. I hope that this will help others in the future.
5 to 4 converter box
For today while I'm waiting on this device I'm going to wire the red brake wire from the truck to the brown running light wire so that I have stop lights and turn signals for daytime use!
