flynniep
- March 9, 2021
- Nantucket
- 1997 Explorer Eddie Bauer
1997 Ford Explorer Eddie Bauer 4X4.
So I've had this car for about a month, it has only one previous owner, impeccable service history and only 90,000 miles on it.
Recently, the power steering went out and the auto shop repaired the pump, pulley, pressure line, fluid and freight parts.
When I dropped the car off the heat was working 100%, when I picked it up it was still warm from the day, so I didn't notice the heat wasn't working until later that night when it dropped down to 30 something outside.
I brought it back into the shop and the guy who did the power steering repair looked at it, all he did was open the radiator cap and leaked fluid onto the ground, then grabbed a flashlight and peered at the thermostat for 5 minutes, checked the coolant levels and then gave me this really vague "hmm well it could be the radiator, could be the water pump, could be the thermostat, not sure until I take it apart"... The radiator is fine, the car hasn't been overheating, the coolant levels are fine, and the system check says the engine temp is ok. So I know they're trying to rip me off, mind you when I came in for the power steering, they told me only the pump would need replacing, and then I walked out $800 later... They also argued with me back and forth about driving the car off the property without getting the radiator replaced...
So I took it to another shop where the guy got into the car, looked at the fuse box, messed around with the temp controls, went under the hood and felt the temp of the water hoses, and said that it was most likely a stuck blend door in the dashboard since there is hot water flowing through.
Has anyone else experienced this issue with this year and model and what was the diagnoses and outcome?
Thank you!
Thank you!
