salmon2day
- June 2, 2013
- St Helens Oregon
- 1997 Ford Ranger xlt
I have some kind of fluid coating the inside of my driver side front wheel and splattering down the side of the truck. It smells like gear oil or tranny fluid. I have checked all my fluids and the only thing that is low is the front differential, about a half inch down from the fill port. I cleaned the truck and the underneath side. I can still smell it but cant see any leaks. There was fluid right under the differential on the cross beam that seems to run down toward the wheel. I have had this truck for 5000 miles, and the previous owner had a new carrier bearing installed.
If it is my differential seal what should I do and what should it cost. the seal does not look to be leaking from the bottom side but I cant see the upper part.
This is a 4x4 4.0 liter engine.
