Nate_V8
- August 15, 2009
- Montreal, Quebec
- 1998 XLT 5L AWD
Hi guys
I have been hearing a bunch of clicking noises coming from the front driverside wheel when coming to a stop and on take off plus there is a minor vibration that is not constant like a tire imbalance. On take off the clicking sounds like it turns into a slight rubbing noise (extremely quiet) which I figure is the minor vibration. It needs to drive for 8-10 minutes before it starts to make the clicking noise cming to a stop and on take off.
From what I have read on here, a lot of people replace the front half shafts and still have the noise and it ends up being the front driveshaft CV joint that connects to the TC. Does this sound right?
I took it in to get it checked and the mechanic couldn't find anything wrong with it but he wasn't looking at the CV joint on the front DS, only the U-joints on the front DS and wouldn't listen to what I had to say unfortunately.
I'm very positive that it is the CV joint on the front DS, there is no rubber boot on it though like the front halfshafts. Is that normal?
I took a quick look under the truck and the joint didn't beat up or damaged, there was no noise from it while on the hoist with the truck in drive. I know I read on here that it won't make noise unless on the ground with load which is why it is hard to diagnose for mechanics not familiar with these.
They told me I would need an entire new prop shaft (I guess they mean front DS?) because the CV joint is not rebuildable but I found this on rockauto and wanted to know if it is the correct part for the front DS
http://www.rockauto.com/en/moreinfo.php?pk=2425736&cc=1304435&jsn=595
If it is can it be installed easily? Does the driveshaft need to be balanced after?
My second concern is I had the mechanic replace the TC fluid (Mobil 1 synthetic ATF) and I bought 3 litres of it just in case. The mechanic drained out the TC, opened one litre and pumped it in and that was it. I don't know the exact capacity but I am pretty sure it is more than 1 litre, unless I am wrong? He said that all the ford TCs take 1 litre. Maybe he was thinking the 4wd TC?
If you guys could answer these questions that would be great! I can't spend much right now and I'm worried that these problems might end up damaging the TC and I can't afford to fix/replace the TC..
