1999 FORD EXPLORER SPORT-BRAKE ISSUES | Ford Explorer Forums - Serious Explorations
brentwhiteley
Pocahontas
1999 Ford Explorer Sport
I have replaced the brake booster, master cylinder (bench bleed before installation), and the front brake calipers. No leaks evident upon a lengthy inspection. Solid brake pedal when the vehicle is not running. When cranked the pedal goes immediately to the floor. I have bleed the brakes from the furthest point (back passenger side caliper) all the way around numerous times.
If anyone has any ideas please reply.
Thanks
ABS system needs special bleeding..... "they" touch on it here and on other threads...
Go to a gravel road
Slam on the breaks to activate the abs
Then rebleed
