SVO42
- December 4, 2002
- RV Nomad
- 1994 XL
I've done some searching and have basically ended up confused. I'm planning on a 2" suspension lift (2" coils and F-150 leaves, possibly shackles) and a 3" body lift. Will I need extended brake lines? If so, at what point? I plan on doing the 2" suspension lift first and leaving the stock wheels & tires on until I get a set of 33s on 15x10s ready to go on, then I'll do the body lift. Will I need longer brake lines at all, after the 2" susp. lift, or after both lifts?
Thanks in advance...
