james8026
- October 19, 2013
- 2000 explorer
ok I have a 2000 explorer xls 4.0 ohv (not sohc) and I have to replace the passenger side head gasket and im wondering a couple things about this job so here goes . do I need to remove the exhaust manifold from the head or can I raise the head up enough to clean the surface and replace the gasket and the reason I ask is because my exhaust bolts as most do are rusted out and would be hell to remove and can I only do the side that is bad? the drivers side shows no signs of a leak and the truck never got overheated the passenger head sprays oil right from the side of the motor and its too high up to be the block so its either the gasket or the head itself but Ive heard these are notorious for blowing gaskets so that's what im assuming. any helpful hints would be much appreciated. thanks
