93rangerturbo
- July 27, 2011
- Wichita, KS
- 1997 xlt AWD
Recently purchased a 302 engine from a 92 mustang that came with a trick flow track heat top end kit installed (newer style with the beveled lip near valve cover). I recently purchased a set of torque monster headers for my explorer as well off ebay, and figured i'd install the entire trick flow heads, cam, intake, kit onto my explorer engine. My question is what should i do about the throttle body and elbow? Leave it stock throttle body, or upgrade to a 70mm or 75mm? if so what do i do about the 90 degree elbow on the stock intake? I plan to run this with 24lb injectors and get a custom tune from henson performace till i can get it dyno'd. Thanks in advance. If you need more info just ask.
