2001 Explorer, How to remove door panel | Ford Explorer Forums - Serious Explorations
54warrior
Lancaster PA
How do you remove the inside, drivers side door panel on a 2001 explorer. I've tried searching with no luck.
I'm not the one removing it. A friend 300 miles away without internet asked me to find out, he's having trouble with it.
Thanks in advance.
Remove the two screws under the door handle, then start at the bottom, pry off the plastic cover carefully. It is held in by plastic "christmas trees" around the bottom 3 sides. The top is held on to a channel that runs along the bottom of the window sill and a small plastic guide "hook" behind the mirror area. I hope this helps.
Thank You.
