2002 Ford Explorer XLT P0775 error.. no check engine light | Ford Explorer Forums - Serious Explorations
MintyFresh
2002 XLT Explorer
4x4 6cyl, trans code V (5r55w) 200k miles
Autozone only error code came up P0775 - Pressure Control Solenoid B
Check engine light never comes on
OD light flashes once I hit second gear+
Revs high when switching to second gear. Engine revs to 3,000 - 4,000 RPM range before shifting to 2nd Gear, depending on amount of throttle applied (i.e. higher throttle, higher shift point).
Won't shift past 4th gear
Transmission is smooth other than that, no slippage, no noises, no grinding
What do you think, Servo or Solenoid pack?
:usa:
