yarrylo
- October 14, 2008
- '03 XLT
Overheated and found the cap on the coolant expansion tank off - I guess I had left it off unless it blew off from the pressure. So I refilled the system and continued to overheat. I found that I was not getting heat in the car, so I changed the thermostat. Now heat works but when I watch the ECT (engine coolant temperature)on the OBDII it is going up to 250F + before I turned the motor off. The temperature gauge on the dash stays right in the middle between H and C. Is this engine in the process of overheating ? In any case how damaging is it to run it like this so long as the dashboard temperature gauge doesn't move from the middle?
