Risso
- June 9, 2012
- 2003 XLT 4.0
I have read a few posts on the forum re: fuel pressures and am leaning towards mine being OK at 60-70PSI but the Haynes repair manual i have states that it should be 28-45psi. I am currently getting 60psi with the key on and around 70 when running. I believe i ihave a regulator on the pump and I have 2 feed lines to the fuel filter of which the larger feeds the rail through the filter and:
the other returns excess fuel to the "fuel pump / fuel level sending unit module. Both the fuel supply line and the fuel return line are pressurised. When the fuel pressure exceeds the upper threshold of the systems normal operating pressure, the fuel pressure regulator opens and fuel returns to the tank via the return line"
( that is word for word from the manual)
Should i suspect a faulty regulator then with my current pressure? Or am i returning fuel to the tank every time i am driving ? - my only issue at present is the long term fuel trim numbers which are approx -11 on one side and -6 on the other - not exactly alarming i suppose.
Thoughts?
Thoughts?
