hvanorden
- November 20, 2012
- Loveland, CO
- 2005 Explorer XLT 4.0L
So I'm pretty sure my motor is toast. While driving it the other day I heard pretty loud "clank" and the motor died instantly. When you tried to start it again it would turn over and you can see the serpentine belt spinning so I knew the crank was spinning, but it sounds like there is absolutely no compression in any cylinder. I assumed it was a timing chain issue. So I opened it up and sure enough the front main timing change tensioner self destructed. The crazy thing is that it somehow caused the keyway that holds the lower timing chain sprocket as well as the crankshaft pully to the crankshaft completely broke right at the timing chain sprocket.
From what I understand, this is an interference motor, so the motor is toast. Has anyone else experienced this before?
