expatexplorer
- November 6, 2013
- 2005 explorer
It may be my lucky day. The trans started to slip and lose drive, eventually losing all Drive and Reverse, but I had low 1,2,3 to get me home slowly. I knew it was not a pump issue, otherwise I would have no drive at all and assumed it was probably a servo bore issue. During the tear down the overdrive planet would not come apart, so I assumed here is the problem. I managed to pry it apart and found the Sprag had failed and locked up the planet. Luckily the planet gears are undamaged and perfect so I will replace the sprag bearing and see how I go.
However, it does not make too much sense to me that if the overdrive planet locks up, how come I would lose drive and reverse, but not low 1,2,3? I pulled the pump apart and it is perfect, the trans was quite clean, a little material but nothing serious. I am still suspicious that it could be the torque converter failure, but lack of material in the trans pan or filter and working low 1,2,3 suggests not.
Does this make sense to anybody?
