andy13mc
- March 26, 2015
- 2005 Ford Explorer
So I'm really hoping someone can help me out here.
My 2005 explorer is having troubles with it's left rear blinker and I can't fix it for the life of me.
So here's the issue... When I try to signal left, the indicator blinks rapidly and the front blinker blinks rapidly... sounds like a bad bulb in the rear right? No. I replaced the bulb. Still the same problem. I then did more research and decided to change the fuse for the blinkers and relay on the fuse box under the drivers side dash. Still no worky. THEN after MORE research, I found out that these explorers have a history of flasher relays going out. So after slaving away trying to fit my massive 6'7" frame and hands in the small spaces of the dash to remove and replace the flasher relay, I finally got it switched out aaaannndddd.... nothing. STILL the same issue.
Any ideas on what the problem could be?? Do I need to actually replace the turn signal bulb assembly?? I'd rather not pay $100 to take it in, but at this point I've spent about $25 and a couple hours worth of my time.
Thanks for reading.
Thanks for reading.
