2005 Mountaineer Stalling | Ford Explorer Forums - Serious Explorations
4x4hokie
Virginia
'94 XLT & '99 XLT
I've got a 2005 Mountaineer, 4.6L sohc, 80k miles. A few days ago I was driving it and it just shut off. I did not panic and just put it in neutral and restarted it. It started normally and ran fine. Today, the wife reported that it did the same thing again. From doing a search here, it seems that the most likely culprit is the fuel pressure sensor, which seems logical. Can anyone confirm that this fixes this problem?
More diagnostic is needed. Could be as simple as a ground issue with the negative cable.
Had the same issue with my 4.0. I took CRC Throttle Body Cleaner and cleaned the throttle body really good and have had no problem since. Good luck!
