1Aauto
EF Vendor
- April 1, 2009
- mass
- 92 explorer
2006 - 2008 Ford Explorer Ignition Coil (Set of 8) for V8 4.6L
BUY HERE: Ignition Coil
The ignition coils are a crucial part of your ignition system. It's function is to convert the 12 volt power of your vehicle's electrical system in to 35,000 or more volts. This produces a high intensity spark at the spark plug which then ignites the fuel in the cylinder. Coils in general will wear out over time. This will cause a misfire condition. In engines like this with one coil per cylinder you can diagnose a coil by putting a timing light on each one to make sure it is lighting the light consistently.
This coil over plug Ignition Coil SET features the following specifications:
Comes as a SET of 8
Brand New
Replaces dealer part numbers: 3L3E-12A366-CA, 3L3E12A366CA, 3L3U-12A366-BB, 3L3U12A366BB, 3L3Z-12029-BA, 3L3Z12029BA, DG 511, DG511
Built to strict quality control standard
Direct replacements
100% factory tested
This coil is a distributorless application. Sold as a SET of 8.
Backed by 90 Day warranty
These are electrical parts and are all tested before they leave our manufacturer. This electrical item is not returnable; it is only eligible for exchange.
