Vby4732
- January 28, 2020
- bourbon
- 07 mountaineer V8 AWD
Hey guys New to the forum just recently picked a 2007 mounty v8 AWD and have a question. It's been making a lot of noises, grinding, humming, everything, po said a wheel bearing was out. So I get it up, four wheels off the ground and drive it everything justs jerks and locks up, then unlocks so disconnect front drive shaft. Try to drive it again does same thing, like the brakes are locking it up or idk. Can you run these AWD vehicles up in the air like that to check for problems, tried it with awd on auto and locked it, traction control on and off. Front driveshaft connected and disconnected. Any help with be appreciated, haven't found anything searching, thank you
