Is there a place on the internet where we can get directions on how to use FORScan
Mod: Don't know if you want to leave this in basic forum or move to MOD section. Kinda gray area since its essentially changing OEM settings. Don't usually do disclaimers but I feel this one needs it. DISCLAIMER: The content listed is for modifying existing code in your control units. You do...
www.explorerforum.com
I don't have the required tools nor am I interested in getting them. I'd just as soon take it to the dealer.
I am replacing the rear deck lid trim piece on my 2013 XLT which currently has a functioning camera. The replacement trim piece comes with a camera. Am I correct in assuming, based on this thread, that the new camera is not plug and play and that I should transfer my existing camera to the new trim piece?
Edit: Note, the new trim and camera are all FORD OEM.
From what I've read and what others have posted, a new camera has to be programmed to the vehicle it is installed on. I would guess that using the original camera would not require programming.
I have a 2011 Limited Explorer and my lines just disappeared the other day. Do 11's have to be reflashed at the stealership or plug and play? I do have the moving lines and park assist.
Tnx, Ken
Tnx, Ken
