moosehead89
- May 4, 2017
- Birmingham, AL
- 2016 Limited
First off, before the search Nazi's drop the hammer, I did search. I've been reading for over an hour. And did find some useful info, like the fact that the bumper has to come off to get the headlight out.
No then, the wife's 16 Limited p/s headlight is having some issues. I noticed heavy condensation on the inside of the lens. The LED DRL strip is out and the LED headlight bulb is out as of yesterday. The condensation is new, I wash it once a week and have not noticed it (and I would have). The high beam (halogen) works fine, I have yet to find where the seal is broken, no rock chips in the lens etc. Looks like a new assembly is in order but prior to going that route is there any chance the moisture may have killed the ballast? Do both the DRL and the low beam work off of the same ballast? Also, if it us just the low beam led that needs changing is there a cheaper source for them? Everything I've found has been close to $200!
thanks in advance,
Moose
thanks in advance,
Moose
