scrivyscriv
- June 1, 2008
- Memphis, TN
- 02 Ranger XLT 2WD auto
My shop manager couldn't even figure this one out.
1996 4cyl Ranger - we just did a transmission filter change, oil change, coolant change, power steering flush, fuel filter replacement, belt replacement, forward O2 sensor replacement, and both radiator hose replacement.
It had codes for a P0144 (not sure if that's the exact code) undefined EGR related and lean condition O2 sensor low voltage. The engine ran much better after changing the O2 sensor. However, when I was almost done servicing the truck, the engine would not crank up. The inertia switch seemed to be part of the problem and we got it to crank up but the engine lacked power - replaced the inertia switch but still the same symptoms. The engine is getting
A) Spark
B) Fuel, and
C) seems to be timed ok - it's making decent compression.
Today we changed all 8 plugs and it cranked up right away but still doesn't have power. I don't have a fuel pressure gauge or a timing light or even a noid light (sheesh... Mac is so expensive...) and we're all pretty much scratching our heads here on it. The owner basically got a free tuneup since the truck was running fine when it got here. But I hate to send it out like this and we've done all we know to do so far.
The plugs were really fouled - seems like it's dumping way too much gas and running rich. But since I've reset the CEL for the O2 and EGR codes I haven't seen any more codes.
Any ideas??:roll:
A) Spark
B) Fuel, and
Any ideas??:roll:
