Gotasee
- January 5, 2008
- Points
- Mesquite, Texas
- 95 Ranger
Newbie here, appreciate the info I have read so far. Here is my story, hope some one can help
95 Ranger, 3.0, 5r55e. Used truck, tranny slipped (seems now like 2-3 flare), tranny shop found bad switch and replaced, helped for a while. Gradually got worse. 70 MOH on freeway lost forward. Towed home. Researched here, looks like VB. Replaced with rebuilt VB from local shop. Old VB had 2 bad gasket locations. Do not have inch/lb torque wrench, non local available, tightened in sequence 4 rounds to shorty ratchet tight, one handed. Filled with fluid, 7 quarts, reverse OK, 1st or 2nd at very high RPM, but feels like it is slipping (feels like bad burnt clutch in a standard), will never grap completely. Raise rear tires off ground, Will go in all gears, and shift, but take hugh RPM to start things rolling. Adjusted bands per thread recomendation, same problem.
Hope this is enough info for some one to help me out. Thanks in advance, Frustrated.
