- September 16, 2002
- Virginia Beach, Va
- 00 4x4 Mounty
First off the vehicle in question is my wife's 03 expedition which has the common 4r70 transmission. It shifts perfectly, acts perfect and never concerned me until here recently when I noticed a "rear end" type whine. It only happens in o/d or 3rd from 40-50 mph on 30% throttle or less. If I let off the gas its quiet. Completely silent after 50 and I don't notice it in any gears but o/d and 3rd. Its loud enough at times to notice it with the hvac blower on high but not like holy crap loud. I have seen the tsb talking about the number 9 torrington bearing and I think it could be my issue but not sure. It seems to come up when the trottle is low which doesn't go with the tsb's description. The truck just hit 140k miles. We have put an easy 1000 miles on it since I noticed the noise (could of been there alot longer as I rarely drive it) and it has remained the same. It's a 2wd 4.6 truck also that only sees 3 car seats and some groceries, never will or has towed anything.
I know the trans needs to be torn apart to fix the bearings and I might as well rebuild it while it's out. Has anyone had this issue in a 4r70 and if so how long did you wait to rebuild? Money isn't really the issue but finding the time to tear it apart before winter won't happen(I'll rebuild it myself). I'll probably drop the pan soon to check for any debris and add a drain plug in just to make sure we are not driving around a ticking time bomb.
