FORD SUV GUY
- December 19, 2011
- VERMONT
- 2000 FORD EXPLORER
I recently purcashed a 2000 explorer XLT 5.0L AWD. w/almost 105k. I bought it w/102k so I havent put many miles on her yet. Anyway when I bought it n finally got it on the road(bought w/blow 8.8 rear diff)I noticed it shifted kindda sloppy n didnt hold the right gear while coasting down hill. At any speed(above 40-45mph) if I come to a down hill grade n let the truck coast, slowing its self down, by time Ive decreased in speed by 5mph the transmission will "fall" out of O/D into 3rd(I think) for usually only a few seconds n then goes back into O/D. Repeating EVERY TIME Im in a simular situation. It has NEVER slipped or not shifted into all gears, but once or twice it has held 2nd gear longer than usual befor up shifting at low speeds. (around 30mph)Not knowing the service history of the transmission compounded by this issue I decided it would be best to do a 5qrt fluid+filter change. The fluid was full and did not appear/smell burt or to discoloured, but upon dropping the pan I found the all to familiar factory build dip stick plug, ALONG w/some unidentified LARGE peices of what appear to be a silicon gasket floating in my pan!! My 1st thought was VB gaskets and ordered the Transgo shift kit(not the recalibration kit), all valve body seals n a new EPC solenoid. Once I received my order I noticed there are no gaskets simular in appearance/composition to what I found in my pan and upon doing some further ressearch its my understanding that Ford did not use a silicone gasket in the VB for my year tranny? (not sure this is correct) but DID use 1 for sealing the extension housing. Is there ANY way for peices of the extension housing gasket to find its way to my pan or do you suppose my 1st diagnosis(VB gaskets) is probably correct, OR am I way off?? It still shifts/drives fine and this is my DD so Id like to have the best idea possible of the problem and parts needed to correct it BEFOR I drop the pan and VB if poissible. I have done ALOT of research on my particular problem and have found no simular threads on it. Really hoping Glacier991 sees this and can offer some assistance. That gentelmnan is UNBELIEVABLY knowledgeable about Ford transmissions. thanks in advance for ANY assitance. This forum ROCKS
NO fluid leaks at all on this vehicle, tranny or otherwise.
