ewalt98
- April 24, 2015
- Bitterroots of Montana
- 1985 Porsche 944
OK, a question for the 5.0 experts on this forum:
I had a lifter that collapsed and would be pretty loud on startup, but then would quiet down after a bit, but not completely in my 98 V8 explorer. I did drive it like that for a while, maybe 2-3k miles.
So, I figured I would replace all the lifters. Once I started it after the lifter replacement, I still had the sound of a bad lifter, not as loud as before on first startup, but just as loud as after the bad lifter pumped up a bit.
The question I have now is, which is the more likely scenario, a bent or very worn pushrod, or a bad cam lobe?
Stupidly, I did not check the pushrods for straightness or length, and I did not check the lift after replacing the lifters. All the pushrods looked straight, and didn't show any abnormal wear, other than the ends being polished. The motor has just over 375k miles on it, so anything is possible. I'm kinda thinking I should pull all the pushrods and check them, but with the miles on the car, maybe I am just throwing good money after bad.
edit: Dang, just checked the price for new pushrods, they are so cheap, why didn't I replace them at the same time???
