bigtang
- July 6, 2009
- houston
- 1998 XLT
Advancing(or retarding the cam) small amounts brings the power in 200-300 RPM earlier or sooner in the power range. Since the GT40p setup doesn't make use of high rpm grunt make that work for you by bringing power in a little sooner.
Make sure you upgrade the springs on the heads, they suck and w/ the 1.7 rockers will fail. Use at least the trickflow spring kit from summit.
I saw an earlier mention of the extreme 4x4 cams, good call skipping on those, I think they are a small base circle cam. will technically fit a roller block but you shouldn't use the spider/dog bone stock lifters.
the short bolts go on the bottom the long go on the top. either use all studs or all bolts so you don't have gasket issues since you preload(torque) them to different amounts and they have different properties under stress(head won't lift or squirm uniformly as it heats and cools)
your pistons should look like this, not a full on dish, but a recess w/ the reliefs, this is the short block from my '90 LX 5.0
