booo66
- February 19, 2009
- chicago,il
- 96 explorer xlt
hi everyone
im going crazy with this truck 06 limited 4.0 131000 miles
no start for 3 days replaced multiple sensors
chains supposedly done feb 2016 since then i have replaced the throttle position sensor 13 or 15 times every week or ten days ,,,,,,6 weeks ago thought i figured it out found chafed or exposed wires on the tps on the maf the egr the throttle body motor and fuel injector #1 ,,
problem continued 4 days ago no start ,,,,thought it was the starter just spinning ..engine cranks very high pitched replaced the starter ,same sound and same result ......no start.....5 hours later a little a squirt of carb cleaner starts up,,,, pull 11 codes all tps and voltage and camshaft sensor next day starts runs 3 times and then nothing ,,,,,so i pull apart all the wiring again ,,,, this time the drivers side too, even tho it all looked fine ....here i found more screwed up wire #4cyl injector wire , camshaft sensor wire ,and fuel pressure sensor wires,,,,,,,,,,,,,,,,,,,,, (everywhere there was exposed or arcing wire it was always 2 to 4 in behind the electrical connectors and under the factory wrap or elec tape),,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,taped it all back up ..put a new tps sensor same **** ,so i replaced the camshaft sensor (figuring arching wires fried the sensor)same thing spinning sound and no start(but its cranking).....(it had a little clatter ever since i had the chains done back in February was told it was normal and it went away after the truck warmed up)
so i got a new fuel pressure sensor and was going to throw it in but i decided to remove drivers side valve cover and found the bottom of the guide is completely gone the upper plastic is still in tact the bottom part of the cassette is gone the plastic and metal ...all gone
the chain is very loose wondering if the timing has jumped if so i do i reset it ........
im going ti take off the timing cover to see whats going on ..the chain is not broke but very loose on the bottom where the guide should be also noticed the #6 cylinder rocker arm is loose ,have spark in all cylinders so i believe that means the crank sensor is good and the the coil is good (correct)what im i looking for beside the obvious broken chain missing theeth etc......i plan on replacing everything in the front of the motor myself but how do i re time it,,, and make sure there's no engine damage before putting new cassettes etc....i have not tried starting it with the new fuel pressure sensor ive done nothing but a lot of reading since finding the loose chain ...(but if the timing is off why did it start and run 4 different times after the starting fluid it sounded exactly the same )
